http://www.trialmaguk.com/2017-jotagas/
Wow !!- Jotagas prove once again. They are not going anywhere , they are just small and niche - and in my book that makes them desirable :). Received today from Jotagas factory, details of the 2017 Jotagas trial bike . As i've always said Jotagas produce a small number of bikes only. They are not a mass producer like the others. Very light , super trick , gorgeous to look at and easy to ride. Available in 125,250,280 and 300cc. £5295. Improvements include
1- revised gear selector mechanism for shorter gear lever
2- movement when selecting gears.
3- new flatslide carburetor
4- new reeds
5- new settings for ignition mapping producing a more linear torque curve
6- new stronger clutch cover which also improves fluid displacement so creating better clutch action
7- new swing arm
8- repositioning of voltage regulator
9- revised higher compression ratio in line with new ignition settings
new colours.
